It is currently Wed Aug 06, 2025 11:57 am
PostPosted: Fri Apr 24, 2009 1:28 pm
Every since Stewmac started caring the OLF plans I have received PM after PM requesting a brace location and shape profile template.
Well at this time I can't say a lot other than to tell you that they are in the works and should be available in the fairly near future. [:Y:] That is all for now more when everything is ready to go!!!!!!!!!
PostPosted: Fri Apr 24, 2009 2:52 pm
here is the teaser
PostPosted: Fri Apr 24, 2009 11:02 pm
First name: Kenneth
Last Name: Casper
City: Northville
Country: U.S.A
Good idea, Mike. I could have used one a couple of months ago! I ended up making my own out of masonite for the OLF SJ. Transferring the layout to the top or back was as easy as extending the brace lines on your drawing out past the perimeter of the body outline. Then after I had cut the top and back a little oversize, I could lay it on your drawings and with a long straight edge transfer the lines to the top and back. Not as easy as having your tracing template, but it worked well.
Will you sell the templates through StewMac?
Ken
http://www.casperguitar.com
PostPosted: Sat Apr 25, 2009 10:24 am
like I said no morre to tell right now
Users browsing this forum: No registered users and 43 guests
